查看: 306|回复: 5
转帖:5053数据线(诊断线)修复
LN5555
发表于 2013-7-8 11:17:25 | 显示全部楼层 |阅读模式
国外论坛转帖,方便大家使用
Hi
To repair your tool please read carfully this thread and you'll find the tutorial for your tool
First of all you need some tools
1. external AVR programmer for Atmega 162 MCU
2. Softwear for programming Atmega 162 MCU
3. Skills in soldering/unsoldering smd components
4. soldering/unsoldering smd components tools ( in somecases you need to unsolder some components and soldered item back )
If your tool is with FTDI FT232RL you need more
5. external progrmmer for GAL/ATF
6. softwear for flashing GAL/ATF
And in the wnd but not the last one you need dump :
7 dump for Atmega 162 MCU ( flash and eeprom ) for the Version you want to use 9 in your case VCDS 11.11.0 - you cna find it here in this forum or in others - it is free )
8. VCDS 11.11.0 original softwear
9. ept (dump) file and Mprog to flash FTDI memory if the tools it is not recognized as Ross-Tech Hex CAn in the Device Manager
If your tool is with FTDI FT232RL:
10. dump for GAL/ATF
Advice:
As many time talked in many forums the computer where you have installed the VCDS softwear may not have any internet connection ever ( not just during the diagnostic session )
EVER, otherwise you'll have same issue anytime
Good luck
LN5555
 楼主| 发表于 2013-7-8 11:18:37 | 显示全部楼层
EPT文件
ept and JED for 11.11.0.rar
2.76 KB, 下载次数: 25
LN5555
 楼主| 发表于 2013-7-8 11:20:05 | 显示全部楼层
处理后的固件文件
打印线路接线修复教程
http://pan.baidu.com/share/link?shareid=2600631493&uk=319274706
另外一套修复教程+文件
http://pan.baidu.com/share/link?shareid=2607624973&uk=319274706
因为5053电路板的格式各样,请注意识别,貌似中文的很特殊,国外的朋友所中文的是OOXX软件来使用的。
貌似他们的是OOXX固件的?国外的5053线使用的一个loader+原版软件使用!
DUMP 11.11.rar
14.91 KB, 下载次数: 25
JS8818
发表于 2013-7-8 11:29:12 | 显示全部楼层
先收着再说
TJ6666
发表于 2013-7-8 12:05:07 | 显示全部楼层
高手~~
发表于 2013-7-9 21:53:41 | 显示全部楼层
好,。看看
GMT+8, 2026-1-20 07:47
