查看: 592|回复: 0
Auchenai Crypts Guide - buy wow gold
发表于 2009-7-31 20:07:35 | 显示全部楼层 |阅读模式
After completing the Mana Tombs and adventuring a bit more in Terokkar Forest and Nagrand, you will be ready for the next instance in Auchindoun, The Auchenai Crypts.
The Auchenai Crypts are a wing of the the Auchindoun instance that is meant for players level 65-67. Many of the quests are available right outside the instance, however you must do a quest chain that will allow you to see the ghosts [url=http://www.bywowgold.com]buy wow gold[/url] that are walking the area before gaining access to some of them. Even if you have not done the preliminary quest the instance is still worth doing for all of the loot from the bosses. The instance is full of Draenei, humanoids and undead Draenei.
The other instances in the Auchindoun are as follows:
            Instance
            MOB Levels
            # of Players
            Mana Tombs
            64-66
            5
            Auchenai Crypts
            65-67
            5
            Sethekk Halls
            67-69
            5
            Shadow Labyrinth
            70-72
            5
Please join us on our forums for more Burning Crusade discussion. You can see more of Ten Ton Hammer's Burning Crusade coverage over at our main Burning Crusade page. As always, click any image in this article to see a bigger version of it.
            Getting to the Auchindoun
http://wow.tentonhammer.com/files/gallery/albums/album69/outlands.thumb.jpg
The Outlands! A complete map of the world and where everything is in it
Getting to the Auchindoun is fairly easy unless you are too low a level, as the MOBS around it range up to level 65. It can be found in the large blasted bone waste area of Terokkar forest to the south of Shattrath City. You can also get access to it from the Alliance or Horde towns to the east and north east. They are the Allerian Stronghold and Stonebreaker Hold respectively. Auchindoun is the large ruins in the center of the bone wastes. When you reach there you have to head down through various tunnels to reach the bottom of the ruins, which is a circular plaza area. In the center is a meeting stone to summon other players and the instances can be found in tunnels around the outskirts of the central area. Another way to get to it is taking any of the stair ways around it up, and then finding a place to jump down through the ruins. There are several places where the ruins form long steps down, sure, you'll take some fall damage, but taken in steps,[url=http://www.wowgoldmvp.com]buy wow gold[/url], its fine.
            Quests
There are two quests that are available to players, one at the start of the instance and the other from A'dal in Shattrath. They are:
Everything will be Alright - Greatfather Aldrimus standing outside the Auchenai Crypts of Auchindoun has asked that you enter the Auchenai Crypts and destroy Exarch Maladaar.
Fight through the instance and destroy Exarch Maladaar who is the last boss in the instance.
Auchindoun... - Travel to the Auchenai Crypts [url=http://www.bywowgold.com]wow gold[/url] in the Bone Wastes of Terokkar Forest and slay Exarch Maladaar to free the spirit of D'ore.
This quest is to once again fight to the end of the instance and slay Maladaar. This is part of a long quest chain that starts with "A Visit with the Greatmother".
            Trash MOBs
http://wow.tentonhammer.com/files/gallery/albums/crypts/Crypts_05.thumb.jpg
Each of the MOBs can summon more...
There are several types of Draenei and Undead that you must be aware of in the Auchenai Crypts. Many have the ability to summon 2 additional ghost like MOBs from thin air before the fight begins, and there are several that patrol areas that pop in and out of reality, so always be prepared for more than you can see. The ones with other special abilities that you need to be aware of are:
Draenei Monks – These Draenei are immune to polymorph and sapping.
Draenei Possessors - These casters can mind control one of the group members. The mind control will not end when the possessor dies however, you must drop the player to 50% health to remove the mind control, at that time they will be healed to full heath and returned to the players control.
Raging Souls – These spirit creatures appear around you and live for about 5 seconds, after which they throw everyone away from them in an explosion. They normally appear on the bridge to the first boss and can throw you off if you are not careful.
            Shirrak the Dead Watcher
The first boss is an extremely difficult fight due to his abilities and having to be especially careful on healing. Expect a few wipes while the group learns the fight. The boss is a beholder type boss (big floating eye) called [url=http://www.wowgoldmvp.com]buy wow gold[/url] Shirrak the Dead Watcher, who has two main abilities abilities and a nasty bleed attack. His abilities are as follows:
http://wow.tentonhammer.com/files/gallery/albums/crypts/Crypts_12.thumb.jpg
Carnivorous Bite - This is a bleed attack that hits everyone in melee range.
Focused Attack - Everyone once in a while (roughly 15 - 20 seconds) Shirrak will call out "Shirrak the Dead Watcher focuses his energy" and a marker will appear near a player. A few seconds after he will attack that spot with 3 AoE blasts that his for roughly 2000 damage per blast! Its range is roughly 15 yards.
Related Articles:
   [url=http://qzxx.200ym.cn/blog/u/loneyen97715/archives/2009/15479.html]Guide to winning the STV - cheap wow gold[/url]
   [url=http://www.tz352.com/bbs/viewthread.php?tid=240&extra=page%3D1&frombbs=1]Priest changes in build 10072 - buy wow gold[/url]
GMT+8, 2026-9-1 14:24
