查看: 734|回复: 0
Guide to winning the STV -
发表于 2009-7-20 12:11:56 | 显示全部楼层 |阅读模式
The Tribe Guide to Fishing the Stranglethorn Vale Fishing Extravaganza
As a (current) three-time winner of the STVFE, I feel that I have established a set of best practices for success in this tournament, and [url=http://www.wowgoldsave.com]cheap wow gold[/url]&nbsp,[url=http://www.wowgoldsave.com]wow gold[/url];wanted to build an authoritative guide for the guild so that others can achieve the same level of success and reap the same rewards. The guide is broken out thusly:
1. Requirements and Recommendations
2. The Rules and The Realities
3. Best Practices
4. Rewards
5. Post tournament rewards
It is a common misconception that this tournament can only be won by a level 60 player. Well I am here to tell you that this is most certainly NOT the case. The tournament is held in STV with good reason: the only requirement to compete in the tournament is that you are able to fish in the STV zone, which means that you must have a Fishing skill of no less than 150, making it possible for anyone able to survive the STV zone to have access to the tournament. However, the rewards of the initial competition do require higher levels of achievement (see the Rewards section for more details).
That stated,[url=http://www.wowgoldmvp.com]buy wow gold[/url], it is recommended that anyone entering the tournament to win be at least level 50 so as to not aggro the mobs that roam the coastline, and have a Fishing skill in the 225+ range to avoid the need for lures (lure application slows your cast rate). As a Horde player, we are also blessed with a distinct advantage in fishing pole [url=http://www.okwowgold.com]cheap wow gold[/url]&nbsp,[url=http://www.bywowgold.com]wow gold[/url];selection, so it is wholeheartedly recommended that you complete the quest in the Hinterlands to get Nat Pagle’s Extreme Angler FC-5000, which gives a +25 to your Fishing skill. I also have a fishing enchant on a ratty pair of gloves, which gives an additional +2 to your skill. It may seem insignificant, but it could be the difference between a catch and a “Fish got away!”
Finally, and I cannot state this strenuously enough, you need a good fishing mod. There are two available out there right now, FishEase and TackleBox, and I personally prefer the latter. TackleBox has a very simple interface and includes the ability to turn on and off self-luring of your pole. It also adds an interface for swapping between your tackle (pole, glove, etc.) and your normal gear, which is pretty swank. Finally, TB is compatible with the Nat Pagle pole, whereas the last release of FishEase that I used was not. Essentially what that means is that, with a fishing pole equipped, you only have to right-click to cast out rather than setting a hotkey, which is a MAJOR plus. Spend a little time pre-tournament fishing with this mod to familiarize yourself with the options available, notably FastCast and EasyCast. You will always want those two on, and they make a huge difference when you see your cast rate versus someone else in the tournament. If you have a high enough skill, leave EasyLure off, as it will just take time away from efficient casting.
The STVFE occurs every Sunday from 2pm – 4pm server time. At 2pm a yell will emanate from BB that the fishing tournament has begun, and swirl spawns will appear in the water, designated as “School of Tastyfish”. The locations of these spawns are static, but the spawns themselves will disappear after a designated number of fish caught, forcing contestants to not only be able to fish well, but be quick on their feet/horse. The object of the main tournament is to catch 40 Speckled Tastyfish from these pools and return them to Riggle Bassbait just outside of the inn in Booty Bay as quickly as possible. Be on the [url=http://www.okwowgold.com]wow gold[/url] coast, at your fishing spot, with your pole in hand at 2pm or be prepared for a long uphill fight.
The realities of this tournament are thus: The main tournament will end no later than 40 minutes into the 2 hour fishing window. I have finished the tournament in times of roughly 37, 32, and 29 minutes each, and the Alliance players that have won in the past have typically done so in the 35-40 minute range. It is essential that you focus all of your energies on catching fish and being aware of where you are, how many fish you’ve caught from a pool, and where you will be going next. Having a fast horse and carrot really helps, and if you have a high enough skill in Fishing and have a pair of gloves with riding enchant on them, I recommend using them instead. If you are catching 1 or more fish per minute, you’re going to be competitive, and time between fishing holes increases as your mount speed decreases.
Related Articles:
   [url=http://space.junyue.cn/?uid-60044-action-viewspace-itemid-259922]Make Gold As A Newbie  - cheap wow gold[/url]
   [url=http://blog.bdall.com/?uid-5350-action-viewspace-itemid-17483]Paladin Class Guide - buy wow gold[/url]
GMT+8, 2026-8-31 09:11
